Illustration of a flood cut: lower 2 feet of drywall removed with dehumidifier and air movers drying a South Florida home
What is a flood cut, and how high should drywall be cut after a flood?
A flood cut is a straight, level cut through the drywall above the highest wet point, so everything that soaked up water comes out in one piece. The height is set by moisture readings, not by the water line you can see. It usually lands between 12 inches and 4 feet, and many crews cut at 2 or 4 feet so new drywall patches in cleanly.
Why the cut goes higher than the water
Drywall is gypsum wrapped in paper, and both act like a wick. Water that stood 3 inches deep on the floor can soak a foot or more up the wall within a day. Saltwater makes it worse, because salt left in the paper keeps drawing moisture from humid Florida air after the floor is dry. So the cut is set by checking the wall with a moisture meter every few inches up from the floor and cutting above the highest wet reading, not by eyeballing the stain.
Why 2 feet or 4 feet
Drywall sheets are 4 feet wide and usually hung horizontally. Cutting at 2 feet lets one sheet ripped in half patch two rows. Cutting at 4 feet replaces exactly one full row, with a single seam to tape at a height where it is easy to hide. Cutting at an odd height, like 19 inches, means more seams, more waste and more finishing. Once the wall is open, the insulation behind it comes out too, the studs and bottom plate get cleaned of salt and dried, and the wall stays open until the framing reads dry.
Can wet drywall be saved?
Not after a king tide. Drywall wet from a clean source, like a supply line that leaked for an hour, can sometimes be dried in place and kept. Floodwater is different. King tide water comes up through storm drains and carries salt, dirt and sometimes sewage into the paper and gypsum. FEMA's flood repair guide says wallboard soaked by floodwater is a health hazard and should be replaced. Drying it does not take out the contamination or the salt, and salty drywall keeps pulling moisture from the air. Not sure how high the wet goes? Check the signs of water damaged drywall.
Can I just cut where the water line is?
It is a common mistake and it usually costs more later. The visible stain shows where the water stood, not how far it traveled up inside the paper and gypsum. Drywall wicks, so the wet section often runs several inches to more than a foot above the stain, and it is invisible from the outside until paint starts bubbling or a musty smell shows up weeks later. Cutting at the stain leaves a band of wet, salty drywall sealed inside the wall, which is exactly where mold grows. The right way is to check the wall with a moisture meter from the floor up, mark the highest wet reading, and cut above it, then round up to a height that makes the patch easy, often 2 or 4 feet. If a few walls read wet much higher than the rest, those get cut higher. The few extra inches cost little compared with opening the wall again.
What should go back in the wall to handle the next king tide better?
If your house is on a street that floods, rebuild the bottom of the wall for the next time. A few options make a real difference. Leave a small gap between the bottom of the new drywall and the floor, hidden by the baseboard, so the board does not sit in water. Use a mold-resistant or paperless gypsum board in the lowest row. Swap MDF baseboards for PVC or composite, which do not swell. In closed cabinet bases, use plywood or PVC instead of particle board. Some homeowners on the isles and near the bay go further and finish the lower section with a material that can be rinsed and dried, like a tile wainscot. None of this stops water from coming in. It changes the next cleanup from cutting and replacing into rinsing and drying, which is faster and much cheaper. We can price both versions so you can choose.
